missing 680x0.library
    Wepl
    Posts: 3 from 2006/1/16
    I have A4000/CSPPC/60/233 128 MB RAM and CV64.
    Made a new SFS Partition and copied contents of MOSPUP ISO to this partition.
    I like to get it working with my Cybervision64. So I copied the cgx stuff (updated with 42rc6) from the 68k system to the mos partition (monitors/cgxlibs/prefs) to sys:.
    When I boot the mos partition I get:
    680x0.library too old. You need version > 46.2
    So copied also the 68060.library to sys:libs. But still the same problem.
    What is the problem?
    Is there guide to get it running using cv64/cv3d?
  • »16.01.06 - 13:27
    VooDoo
    Posts: 189 from 2005/8/24
    hmm..very strange..du you use last MorphOS PowerUP update?? The first PUP version dont have 040/060 libs in archiv..
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1  :-D
    Warp croatian Amiga portal :
  • »16.01.06 - 15:24
    Wepl
    Is there an update? I used the iso from http://powerup.morphos-team.net/
    Anyway I got it working by simply adding the 68040.library too.
    It seems the boot/startup opens the library (can be find in the binary together with the error message).
    A bit slow gfx but working now :-)
  • »16.01.06 - 21:07
