For sale: Pegasos 2 complete system
    nine
    Posts: 46 from 2006/6/14
    I'm selling my Pegasos 2 system. It's simply not getting the love it deserves, and I hope another MorphOS user can give it a good home.
    The specs are:
    [list]Pegasos 2, 1GHz G4 system[/list]
    [list]1GB DDR memory fitted (2* 512MB)[/list]
    [list]160GB Seagate Serial ATA hard disk (attached via SATA to PATA adapter)[/list]
    [list]NEC USB 2.0 card (MorphOS compatible)[/list]
    [list]ASUS Radeon 9250GE card (128-bit memory bus, unlike the stock 9250 card which is 64-bit)[/list]
    [list]Fitted in a black X-QPack "cube" case, with front handle, top and side windows. I've also installed blue case lighting, which is quite useful for checking on the CPU fan[/list]
    It's fairly young - I received the motherboard in late 2005 (new), and the parts were purchased during the time I received it and early 2006.
    I'll preinstall MorphOS 2.2 for you, and Linux as well if you require. Please let me know your installation requirements. I have not purchased a MorphOS 2 license so it will be the time-limited version. Alternatively I can install MorphOS 1.4.5. I have purchased a Poseidon license key as well so the installed USB 2 card will be unrestricted.
    The item is listed at eBay, including pictures and a shot of MorphOS 2.1 running on the machine.
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330297273810
    Thanks for reading,
    nine.
  • »28.12.08 - 18:10
    amif1team
    Posts: 16 from 2007/6/30
    Sorry for bad English - how much ?
    [ Edited by amif1team on 2009/2/1 10:53 ]
    -=\ amif1team /=- team Dogma
    http://www.dogma.org.ru
    http://www.amiga.org.ru
  • »01.02.09 - 06:52
    npanag
    Posts: 8 from 2008/7/17
    It was on e-bay my friend. Check the link in the post above
    Pegasos II G3/600 Mhz + MorphOS 2.1
    EFIKA MPC5200/400Mhz + Debian Linux
    www.amigaplanet.gr
  • »04.02.09 - 18:20
