creating hard file image on bochs
    serge
    Posts: 725 from 2003/2/20
    I want install Win2000 on bochs, but know ho to creat an hard disk image file with 1 GO.
    HELP !
  • »09.11.03 - 12:35
    Posts: 126 from 2003/2/17
    Don't install 2k... there is no way to send the Ctrl+alt+suppr combination to the system... and it doesn't work from keyboard... there should be some button in the Bochs GUI, but it simply doesn't work
  • »09.11.03 - 17:06
    serge
    OK, Is BXimage a Morphos tool or linux ? Does it exists for windows? I found only the liux version.
  • »09.11.03 - 17:48
    serge
    tokai wrote:
    use the provided bximage tool.
     :-P sometimes I'm a little stupid. Thank you very much to open my eyes. :-)
  • »09.11.03 - 19:25
