PEG 2 boot problems... help needed (newbie!)
    Posts: 4 from 2007/6/12
    Hi all,
    This is my first post, so I hope I?m not making a total fool of myself!
    Also, I hope I've posted in the right place!
    I just got myself an excellent Pegasos 2;
    G4 1GHz processor
    80GB Hard Disk
    CD-RW
    Radeon 8500 Graphics Card
    512MB RAM
    MorphOS 1.4.5
    OpenFirmware 1.2
    My problem is this after installing the basics (MOSNet, IBrowse, AmiNetRadio, fxPaint etc...).
    The system stops booting at the MorphOS logo, it was working fine for hours before doing this.
    If I leave the CD-RW door open and reboot, after the door automatically closes then it boots fine, or if I leave a CD in, it boots fine.
    I have tried several clean install and these are fine, it does seem to relate to whatever I have installed, but thought I would pick some brains here to see if anybody else has ever had this, and if there is a way around it.
    I have checked the user-startup and the other scripts, but all seems fine.
    Any ideas?
    Thanks in advance :)
    [ Edited by Zero on 2007/6/16 19:28 ]
  • »16.06.07 - 17:26
    DJBase
    Posts: 745 from 2003/4/6
    Add "Wait 1" before IPrefs in MOSSYS:S/startup-sequence
  • »16.06.07 - 17:40
    YES!!!
    That done the trick, thanks!
  • »16.06.07 - 17:59
