My Efika pics
    wolfe
    Posts: 118 from 2003/8/7
    Having fun are we?
    efika - top leads me to geo cities, not a picture. Might want to check that.
    Needs MOS . .  :-P
  • »02.03.07 - 01:52
    Posts: 8 from 2007/2/20
    Didn't know that geocities impose a data transfer limit. I moved the pics to flickr now.
    @wole
    Yes, I hava had the board since Wednesday and I like it very much. It is small and elegant. This might sound strange but I like that it has the cpu and memory fixed because the software that will target this board will have to be optimised (similar to consoles).
    I might write a small review once I have it fully operational with linux. I want to use it as a file server (and maybe web server too if it can handle tomcat).
  • »02.03.07 - 08:30
    Furvert
    Posts: 83 from 2004/4/20
    Not sure why but the links above are stating I'm not logged in and crashing ibrowse something nasty :P
  • »02.03.07 - 09:32
    Nitro
    Posts: 106 from 2003/8/24
    Hi astrofos,
    I have the same case. It's a good fit. I'm using cardboard for a backplate until I have time to cut one from metal.
  • »02.03.07 - 10:12
    wolfe
    @astrofos
    Having the memory fixed is something I don't like, unless it comes with enough memory for future needs. As I see it, 256mb would have been better. Better to have and not need, than to need and not have a way to upgrade it without a soldering iron.  :-o
    Don't have one yet. Haven't been able to justify the cost, its use etc. . . :roll:
    Maybe that will change when MOS 1.5 is available. Maybe a luggage-able laptop thingy? Car-puter ? . . .  8-)
    I would have purchased one already if it had onboard graphics and a few more features, and MOS. I don't care that it doesn't have a cd/dvd connector because I use an external burner (NOW) to share with all my cpu's. Beats buying a cd/dvd for each unit.  :-)
    Don't have too much fun now . .  ;-)
  • »02.03.07 - 14:55
    deez
    Posts: 53 from 2003/5/28
    @astrofos
    Hi
    Can you tell me what brand and model number is that keyboard on the photos ?
    [ Edited by deez on 2007/3/3 3:07 ]
  • »02.03.07 - 21:14
    @deez
    see pm
  • »03.03.07 - 21:14
