"software Tycoon" of the "spuer Bundle" doesn't work
    AC-Eule
    Posts: 129 from 2003/4/19
  • »10.08.03 - 06:15
    klapdeur
    Posts: 132 from 2003/6/28
    hi dude i had the same lha eroor with the ahi package in software tycoon but here it works fine i just took the other files and leave ahi then i burned it to cd and installed it and you can play.
    the only thing that is not good is the ahi drawer in that package the game is perfect
  • »10.08.03 - 06:47
    AC-Eule
    Thanks for the reply, until now I tried to install Software_Tycoon
    from a dirctory. I think I will burn it on a CD. Maybe there is a
    magik dfferenece between an assign and a CD with the real name.
    cu Eule
  • »10.08.03 - 07:36
  • HAK
    Posts: 225 from 2003/2/24
    @ AC-Eule,
    Hm, I downloaded the file from the FTP-Server tonight and unpacked it
    into RAM: with the lha that cames with MOS 1.4 (I also got the error,
    but it didn't bother me to much 8)).
    However - just for checking:
    The file I downloades has a size of 73823737 bytes and the MD5
    checksum is e8c694ee8dd42c2e1fa67fa0df2fd51e.
    I did no installation as such - just took the directory
    "SoftwareTycoon" (which was in the main directory) and dragged it into
    my games directory on my HD - that was all.
    Started it and it did run - no need to install the accompanying AHI
    over the one from MOS.
    Bye HAK
  • »10.08.03 - 08:22
    AC-Eule
    @HAK
    hey this was the right idea. Waht I made wrong I after
    decrunching Software_Tycoon.lha I clicked instal in the "Software
    Tyconoon" Directory. and the installed game did not work.
    But without installing it is working perfectly, I could just start it
    in the direktory where I decrunched it ....
    This is the first time 'installing' is the wrong way to get the
    software installed..
    Thanks for your help.
    Cu AC-Eule
  • »10.08.03 - 08:36
