mame screenshots
    serge
    Posts: 725 from 2003/2/20
    2 questions about mame 0.84
    Can we do screenshots with MAME 0.84 ?
    Are they displayed on the write side of the GUI ?
    thnx.
  • »09.08.04 - 16:27
    Posts: 979 from 2003/6/28
    Why not MAME 0.85 ?
  • »09.08.04 - 16:38
  • DDJ
    DDJ
    Posts: 99 from 2003/2/23
    I had to reconfigure the key for this because the default configured key doesn´t worked here, but yes, it works in MOS Mame 0.84, Just hit the TAB key and take a look at keys config in general when you start to Play something.
    Peg2 G4 1Ghz rev. 1.2 - CPU rev 1.2 - Built on 20050808
    OF-version 1.2 (20050808153840)
    Radeon 9250 (9200Pro) 256MB/128bits AGP - OEM PCVIEW (ProLink)
    RAM 1GB - 2x512MB DDR333 CL2 - Kingston HyperX
    40GB ATA100 - Brand ?
  • »09.08.04 - 17:33
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    If i remember correctly, the default key to make a snapshot is 'help' (menu key). And yes, the gui displays the available screenshots. If you want to add snapshots coming from internet or whatever, put <romname>.png files in snap/.
  • »09.08.04 - 18:58
