Posts: 451 from 2006/11/16
I have an adapter into which 2 9pins old type joysticks go and this adapter provides a usb connector to connect to the usb off my powerbook.
I had this adapter working on my peg2 with mos but I lost my settings for poseidon in the hid.class action part.
There you must set up the actions performed at the data poseidon receives from the joystick.
I can't get it to go ,this because I don't understand the syntax off the action parameters.
The fire button is easy that's working now.
But for all the other directions what for settings?
I mean there is a toggle and also a push and a assign what is the differnce?
Maybe anyone has a working setup for a suzo the arcade setup which I can copy/use?
