Some applications that don work with MorphOS 2.0
    Charvel
    Posts: 97 from 2007/2/15
    Hi.
    I have some programs that I want to use but I cant get them to work correctly or at all in some cases.
    1. Amitradecenter
    Something with Nlisttree.mcc.
    I have tried to switch the sys:MorphOS/classes/mui/nlisttree.mcc to that one included in Amitradecenter but with no luck.
    2. April
    Tells me: Could not create mui application.
    The last snoopium says is open MagicWB. Do I need to install MWB?
    3. Amiftp
    Same as above.
    4.Simple mail
    Same as above.
    5. Many OS4 programs dont work in OS4 emu. Complaining about diffrent librarys. Where do I find these?
    6. sabremsn
    Cant open muimaster.library
    Last thing snoopium says is open MagicWB.
    Edit:
    7 My system goes VERY unstable right now.
    Photofolio, Wookiechat and some other programs crashes very fast after opening.
    Would be very very nice with some help with these questions.
    Thanks.
    //Peter
    [ Edited by Charvel on 2008/8/17 13:48 ]
  • »17.08.08 - 10:23
    Framiga
    Posts: 363 from 2003/7/11
    "1. Amitradecenter
    I have tried to switch the sys:MorphOS/classes/mui/nlisttree.mcc to that one included in Amitradecenter but with no luck."
    reinstall the original MOS2 nlisttree.mcc (that one is an old 68K one)
    Try the latest ATC 1.4
  • »17.08.08 - 10:36
    Toto
    Posts: 268 from 2003/4/20
    I think you are missing some MUI classes. AmitradeCenter, April, SimpleMail work fine here after adding the missing classes (don't remember which ones, use Snoopium).
    I don't use the other programms you listed but I guess the same applies to SabreMSBN and AmiFTP.
    toto
  • »17.08.08 - 10:41
    Charvel
    I have replaced the nlisttree.mcc to the original MorphOS 2 but still not working.
    I downloaded the latest ATC from aminet I think.
    Maybe its not the newest. Its still not working.
    Where do I find those muiclasses?
  • »17.08.08 - 10:45
    Toto
    You also might consider reading the manuals of the programms because they list the required files in the manual :-)
    Like SimpleMail and AmitradeCenter.
    [ Edited by Toto on 2008/8/17 14:00 ]
  • »17.08.08 - 10:46
    Charvel
    Yes....I know about that... :)
    But still, I dont know where to search for those classes.
  • »17.08.08 - 10:49
    Toto
    You can find some here and on Aminet.
  • »17.08.08 - 10:53
    Charvel
    Thanks! =)
  • »17.08.08 - 10:54
    Dworkin
    Posts: 5 from 2004/7/22
    Hello!
    I have the same problem with PhotoFolio v2.31 and Mos2.0; something goes wrong with MUi (NListtree...), since Mui 20.6381... and Mos 1.45 :-(
  • »17.08.08 - 12:02
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    Charvel wrote:
    Hi.
    1. Amitradecenter
    2. April
    3. Amiftp
    Same as above.
    4.Simple mail
    Same as above.
    6. sabremsn
    Edit:
    Thanks.
    //Peter
    Did you get any of these working?  :-?
  • »30.12.08 - 06:01
    Posts: 1520 from 2003/2/24
    3. Amiftp
    Same as above.
    Try AmFTP instead, it is much better. AmiFTP is not good FTP client....
    Most of OS4 programs fail to work because OS?Emu does not have a wrapper for all Reaction classes. MUI compatible OS4 software should work.
  • »30.12.08 - 06:23
