are there problems with my dvd drive ?
    Brumiga
    Posts: 266 from 2004/4/3
    hello guys,
    since i have my pegasos 2 i am not able to use my dvd drive to read dvds zone 2, europe, with Frogger or MPlayer. that dvd drive is a Samsung SD-616F. i also tried to copy the content, from shell, DOpus 4.1x or 5.5, and i obtain an error 296 on the .vob files. i am thinking about purchasing Frogger but this one would have no sense if i cannot solve that dvd drive problem. what/where is the problem ? is the dvd drive not set to the correct zone ? should i have to put it in a pc under windows to verify if then it can read dvds zone 2 and if not to try to set it to this zone 2 ?
    Brumiga
    [ Edited by Brumiga on 2004/7/16 16:34 ]
  • »16.07.04 - 12:33
    ChatDEau
    Posts: 248 from 2003/4/4
    I think that problem is already known but the interested person, laire.
    Someone told me he is aware of the issue, but I don't have any further information as wether or not this will be fixed in MOS 1.5.
    If I'm not wrong, Error 296 is a read/write error.
    Fred
  • »16.07.04 - 13:16
    Brumiga
    hello Fred,
    thank you for your little answer.
    i will wait for other answers from specialists of MorphZone. does anyone think that i should sell this dvd drive and buy an other model from a different manufacturer whose models are known to work correctly under Morphos with MPlayer or Frogger ?
    Brumiga
  • »16.07.04 - 13:40
    tokai
    Posts: 1289 from 2003/2/25
    read errors are normal when you try to playback the .vob files from a encrypted DVD directly.
    Use the MPlayer commandline. If you have problems with that: I made a small shellscript which you can find under the "furnance/tools" section on my homepage (see signature).
    regards,
    tokai
  • »16.07.04 - 13:44
