PegXMac and Ethernet
    DrZarkov
    Posts: 142 from 2004/3/21
    MacOS X is running very well, with one problem: On my Pegasos II the internal ethernet-ports are not working, so I have to use a pci-card, on MorphOS-side with the rtl-8139pci.device.
    How I can use this card under MacOS X? Im using MacOS X 10.2, I've installed the drivers coming with MoL.
    BTW: Sound isn't working, too.
  • »05.05.04 - 16:08
    magnetic
    Posts: 2129 from 2003/3/1
    I dont know about pegxmac but you really should be using the 2.6.4 kernel with your peg2. This gives alot of gfx speedup as well as ALSA sound built into the kernel..
    magnetic
  • »05.05.04 - 16:49
