UAE for MorphOS
    Posts: 1932 from 2003/10/19
    I got the build for MOS, but no matter what I do it just wont run. SnoopDOS shows it attempting to change to ram disk or something. No GUI comes up, and it loops in this ram thing in snoop untill I reboot. What gives?
  • »25.04.04 - 22:23
    Spidey
    Posts: 568 from 2003/2/24
    Hello Acill,
    Please search in the earlier threads for UAE, I'm sure you'll find an answer to your problem. :-)
    Bye,
    Spidey
  • »26.04.04 - 03:37
    Aaron
    Posts: 127 from 2003/6/14
    Acill,
    Like you, I had trouble making UAE work. Then I downloaded DJBase's
    0.8.22 archive and it worked without a fuss.
    Go to www.djbase.de
    --Aaron
    --Aaron Diezman
  • »26.04.04 - 05:41
    That one did it! Well I can at least run games and get it going. Does it have any settings to keep that big text window. Also if I click the close gadget it wont close, I have to reboot. It seemstowork fine other then that. Thanks and any more tips would be great.
  • »26.04.04 - 11:04
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    To quit, either ctrl-c in the shell and type 'q', or use the arexx port and type rx "address UAE quit".
    You can also use the included gui. Just make sure you have muirexx and a non os3.5-enabled icon.mcc (the oldest one on aminet should be ok).
  • »26.04.04 - 14:48
    Posts: 979 from 2003/6/28
    When we will have a port of the latest UAE/WinUAE for MorphOS???
  • »26.04.04 - 20:09
  • Fab
    Fab
    I built the latest 0.8.25 from R. Drummond to check. It works, however, it seems a bit less compatible (i really wonder why) with somes games such as turrican2.
    Sound seems to 'cut' a bit less than before, but this may just be an illusion. :)
    Anyway this is still not perfect, and audio output section should really be made asynchronous.
    I fixed virtual fs support which was broken in the 0.8.25 aos port.
    P96 support for aos port is still missing though.
  • »26.04.04 - 21:02
    I got the version you told me to get, but no matter what I do its jerky and wont run any games smooth. The sound is good, its like its pausing on and off sort of. Take a few steps, stops then goes again.
  • »27.04.04 - 01:34
