Suggestion for Latest Posts
    Stingray454
    Posts: 18 from 2006/8/23
    I often enter MZ just to see what has happened in the forums lately, and use the "Latest Posts"-list on the entry page. I guess many others do this as well.
    One thing that keeps annoying me is that when you click a subject, you get to post #1 of that thread, and you have to click the latest pagenumber to get to the new posts. This means "click subject -> pagenumber -> read post -> back -> back" for each subject.
    Can this be changed so that when you click a subject you view the latest post instead? Ie, it's "Click subject -> read post -> back". Since the page loads fairly slowly to me and I check it quite often, it's a bit annoying.
    It's a very small thing really, but I thought I'd ask at least  :-D
  • »17.10.06 - 08:15
    Krashan
    Posts: 1107 from 2003/6/11
    You can easily change order of posts display. It can be set in your profile. Just edit it and set "newest first" order. Then after you log in to the MorphZone and then click on a topic subject, you will get the newest posts on the first page.
  • »17.10.06 - 09:08
    Stingray454
    Oh.. How embarassing :oops:
    I wasn't aware of that option! thanx a million  8-D
  • »17.10.06 - 09:38
    hooligan
    Posts: 1948 from 2003/2/23
    @Krashan
    Still, I think it would be nice to get direct links to threadpages. Wouldnt hurt anyone.
    ps.This is maybe the millionth time I am mentioning this.. maybe Targhan will now make it happen ;-)
  • »17.10.06 - 11:55
