mount.library
    Ezrec
    Posts: 2 from 2011/10/4
    If I was to implement a new removable storage device driver, how would I use mount.library to set up the automatic filesystem mounting and notifications?
    The docs in the SDK aren't too clear on what needs to be in the device unit, and what should be in the filesystem.
  • »04.10.11 - 16:41
    RSchmidt
    Posts: 12 from 2006/10/30
    mount.library is an internal library and subject to change any time. If some references got leaked into the SDK it wasn't intended.
  • »06.10.11 - 19:18
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 11.11.2011 - 07:19 ]
    Pegasos2 G3, 512 megs RAM
  • »06.10.11 - 20:38
    Ezrec
    Well, that's disappointing.
  • »17.10.11 - 18:17
