mui height and width.
    rebraist
    Posts: 96 from 2011/4/6
    Hi!
    I have a situation like this
    hgroup
    button1
    vgroup
    button2
    button3
    end
    button4
    end
    i would like that the height of button1 should be the same of the sum of the heights of button2 and button3. if i can make a drawing something like this:
    o=button1
    :=vgroup of button2 and button3
    o=button4
    o:o
    i tried with fixed height but it gave me nothing.
    the entire group is inserted in a "main" vgroup with other buttons.
    just another question:
    can i insert two sequential vgroup? something like this
    vgroup
    end
    vgroup
    end
    THANK YOU!
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »15.05.11 - 18:33
    Krashan
    Posts: 1107 from 2003/6/11
    Text buttons are normally sized vertically to the text height. To switch this off, set MUIA_Text_SetVMax to FALSE. Then it will have the same height as vgroup containing button2 and button3.
  • »16.05.11 - 02:08
    rebraist
    thank you! you're always precious!!
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »16.05.11 - 06:55
