E-UAE AHI-driver and network support ?
    jalla
    Posts: 57 from 2004/10/4
    I have recently used E-UAE quite much and it's working well.
    There are still 2 questions I have..
    1. When it comes to AHI sound. Are there any driver available to make E-UAE to make use of the Pegasos built in soundcard ? Tried a VIA driver from the Amithlon distribution without succsess. Only paula works for me so far.
    2. The bsdsocket.library. Will this be implimented in future versions or are there already available shortcuts using the serial.device in the emulator and a nullmodem device on the pegasos side to push the network access over to the amiga side ? Or a transparent pegasos driver ?
    Got 6 configurations in my setup. WB1.3 , WB3.1 , OS 3.9 with and without harddisk support. The last one uses picasso96 and a screen resolution of 1400x900 supprisingly fast. Thanks to fab for the port !!
    [ Edited by jalla on 2010/10/24 2:00 ]
    [ Edited by jalla on 2010/10/24 2:02 ]
    Pegasos II/G4/512MB/Radeon9200
  • »23.10.10 - 19:50
