Booting a Powerbook by USB pendrive?
    osco
    Posts: 680 from 2009/10/20
    USB boot is different on PowerBook. Download morphos.iso and put iso image and mac_ppc32/boot.img to your pendrive.
    boot ud:,\boot.img bootimage=umsd0:morphos-3.1.iso
    (bootimage keyword can be shortened to bi)
    Just in case someone doesnt know: to get an access to OpenFirmware on Apple machines hold down apple + alt + o + f keys.
    (FAT32 partitioning is assumed. I dont know if Apple firmware supports USB boot from any other common file systems there. Amiga file systems certainly are not supported there.)
    [ Edited by itix 27.07.2012 - 20:26 ]
    It is also possible copy all files to USB pendrive and boot using bootdevice argument. For install/update purpose using iso image is certainly better.
    Where is the directory for mac_ppc32boot.img?
    Where on the pen drive do you put the iso image and mac_ppc32/boot.img?
    boot ud:,\boot.img bootimage=umsd0:morphos-3.1.iso ? is there a prompt after hold down apple + alt + o + f keys. ?
    My pendrive is formated Fat16 will it work as well?
    Have Powerbook which has no OS and no CD drive. Will the pen drive boot this Mac into Morph OS?
    [ Edited by osco 12.01.2013 - 09:54 ]
  • »12.01.13 - 12:52
    Posts: 1520 from 2003/2/24
    Boot image is inside ISO image. Copy both boot image and ISO image to the root directory of your pendrive, hold down apple + alt + o + f keys and you get open firmware console where you can type boot command.
    FAT16 probably works.
  • »12.01.13 - 16:02
    Norbi
    Posts: 99 from 2004/6/19
    Morphos on my MacMini booted from a USB FAT32.
    The whole system was copied from the ISO.
    Boot.img for MacMini just moved to the root.
    boot usb0/@1:1,$boot.img bd=umsd0 rd
    Previously you should check whether OF sees pendrive.
    Top list the files from the flash drive.
    for example:
    dir usb0/@1:,$
  • »12.01.13 - 16:45
