disabling one cpu on a dual processor board
    Do you think this would be possible and how would you go about it?
    Would a Power mac run with one non-functional processor?
    the main reason I'm asking this is I'm having trouble locating a single 1.33 GHz Xserve cpu card.
  • »28.05.12 - 20:06
    Should be possible. I had one Mac user tell me that he made a mistake while overclocking his G4 PowerMac and had one of the dual G4's running at a slower speed than the second one.
    He suggested to me that instead of using a single G4 CPU board in my dual G4 PowerMac, that I could just lower the speed of the second G4 CPU as much as possible to reduce heat production.
    Personally I am still going to use my single 1.25GHz G4 CPU board in my dual 1.25GHz G4 MDD PowerMac and over clock it to as fast as I can go while still having a stable system for running MorphOS on.
    There have been users who have reported overclocking the 1.25GHz G4 all the way up to 1.67GHz while still running stable. Even if I can only get mine up to 1.5GHz, that will be acceptable to me.
  • »28.05.12 - 22:31
    I agree that the 1.25 GHz single cpu board would be easiest (and i have one), but the 1.33 and 1.42 boards have more L3 cache per cpu.
    I wonder if i could just pull one with a heat gun?
  • »28.05.12 - 23:17
