Dual booting the easy way.
    I just finished adding some hardware to my Quicksilver Powermac.
    I purchased a surplus APS external SCSI drive housing from a vendor on Ebay.
    Originally it housed an 18GB drive which I've replace with a 75GB 15K RPM Ultra320 drive using an 80 pin drive adapter.
    The drive connects to the original power and controller cables of the housing and I have the whole thing connected to an SCSI controller in my Mac.
    Now when I have the drive powered, the system can boot OSX (quite fast).
    And when its not powered, the system boots MorphOS from the internal ATA100 drive.
  • »08.03.12 - 22:47
    I couldn't resist updating this setup when the chance came to get a good buy on an eSATA controller card.
    I just won a Sonnet Tempo X4p PCI-X SATA II RAID card on Ebay ($25 plus $15 S&H).
    It will work in my G4's PCI slot and can be moved to a G5 later.
    I also picked up a Rocketfish RF- HD3035 SATA Hard Drive Enclosure so that I can install one of my SATA II hard disks into it.
    Now I just have to figure out what to do with the SCSI hardware (I think I'll use it in my PC to backup my hard drive).
    Edit - What to do with the SCSI drive? Keep it. The TempoX4p does not support bootable drives! My mistake. I guess I'll save it for use in a G5.
    [ Edited by Jim 29.03.2012 - 17:49 ]
  • »28.03.12 - 00:04
