Posts: 566 from 2007/12/10
Score! Turns out that my Powerbook 5.6 has 128MB VRam after all! It's listed on Everymac as an option, but as it was not mentioned by the seller I naturally assumed that it would be the standard 64MB model.
Reading this I want to ask this question. As some of you may remember I have bought an 1.67 HiRes PowerBook, sold it cause I found a cheaper one locally and for this second one I am still on quest for an a1139 logic board after an accident.
Everything started when I tried to add a wireless network card on this PB as it appeared not to have one. I have ordered the correct wireless device for the 1.67 HiRes model -M9970LL/A- which is diffrent from the 1.67 LowRes model -M9689LL/A-.
As I turned up the machine it switched normally to 1680x1050 mode so it is confirmed to be a hires model, the VRAM was 128 MB and the main RAM was 2 Giga the mahcine was preety fast.
However when I opened the machine to put the wireless card I discovered that the network device was not the suitable one and that the one that was ready to fit was the one used on the LowRes -M9689LL/A- model. I ordered the correct card.... And went on to put it...
Also all the instructions on ifix.com that I found for the Hires motherboard -to change the card- would not fit on this motherboard however the instructions for the LowRes motherboard were ok.
What I am trying to describe is that I have a Hires Powerbook with a LowRes type of motherboard or a motherboard with some LowRes components installed. And I wonder two things / options / scenarios:
a. Was there any kind of silent upgrade by Apple? I am searching the net but can not find anything... Perhaps a silent upgrade to the 17'', 1.67Ghz LowRes models before the official release of the HiRes ones.
b. Perhaps the motherboard was changed on service..... -by the previous owner-.... But WTF? This is a modified one.
As the keyboard connector in this PB is now broken... -it was almost from the firt ttime but after some open and closes to change the network card it toally broke- the PB is on a specialist who tries to fix it. If he does not I am after an A1139 mobo... BUT I am afraid that even a purchase of a new one would not probably fit in this wird model.
All kinds of information or ideas would be useful.....
I mainly think about this silent upgrade case... What do you think?
Ok if I have kept my original PB thta has just a little fade on the PB logo and a small dent I would not be in this adventure. But as the first one cost me a lot and as I have found the second one in a lower price and on the same time found someone who wanted to get the first one ib the original price I paid.. ok I did the exchange. But now I have learned the lesson: when you have something and it works ok, just ... keep it!
