Posts: 539 from 2003/2/25
Until today, the DVI of my Mac Mini were working correctly. After a reboot, the LCD screen stayed black. VGA is working at least and let me post this here.
I tried to change screenmode, change monitor specs in Monitor Prefs, tweaking resolution & all but still black screen.
Debug log shows that DDC info is found on CRT2.
All this is a bit annoying. VGA output in native resolution is somewhat broken (big offset to the left unsolvable with mode editor). Currently in 1400x1050 instead of 1680x1050. Fuzzy & blurry display. Really annoying in fact (even more when you are used to crispy digital display...).
Booted with CTRL to start in 1024x768@60, LCD screen stayed black as well.
Do any of you had such problem ? Perfectly working DDC/DVI and then... no more working. I still have to test the DVI input of the LCD with another computer but I don't have any other computer with DVI output currently at hand...
Any advice welcome.
Czeko
