Problem installing MorphOS
    Dougal
    Posts: 77 from 2010/10/22
    Hi... I am new here :)
    Ok here is the story. I got a Power Mac G4 with MorphOS installed. It worked perfectly.
    I wanted to have both OS X and MorphOS, so i found a PDF with instructions to make a dual boot system. I followed the instructions.
    I partitioned 3 partitions. One for Boot, 60MB, One for MorphOS, 2GB and the other for OS X. I then installed OS X.
    OS X fine.
    I booted MorphOS cd and went to install.
    I have been following the step by step instructions perfectly so far.
    Anyway once i got to the storage part of the MorphOS installation and i clicked on the 60MB partition (called boot) i got this error:
    "Invalid partition Layout!" and some stuff about the sector range.
    I have no idea what to do.
    As an alternative, i installed another HD, but every time i went to install MorphOS it would freeze just before the part where one would press install.
    So i put in the Morphos HD as the Primary HD (Master) and Morphos installed and ran correctly.
    But then i put it back to SLAVE. Switched on and held ALT for boot menu.
    Selected the MorphOS drive and got stuck on the grey screen. Frozen.
    I really want MorphOS and Mac OS X but its really giving me grieve.
    Any help would be appriated .
    Thanks
    Power Mac G4 1Ghz (Sonnet Encore) 640Mb, ATi Radeon 9000 Pro, USB 2.0
    OS: MorphOS 2.6 (Registered) , Mac OS X Tiger 10.4.11
  • »22.10.10 - 14:09
    Dougal
    Help? Anyone?
  • »23.10.10 - 05:30
    koft
    Posts: 7 from 2010/6/24
    Dougal wrote:
    Help? Anyone?
    I have never tried it but someone will help you, hang on man. (:
  • »23.10.10 - 05:34
    Ruud
    Posts: 335 from 2009/2/2
    Hi Dougal and welcome :)
    Not sure i can be of much help but one thing that might be worth checking is that all your ide cables are 80 line. Morphos doesn't seem to like 40 line cables.
  • »23.10.10 - 06:58
