How do I type the hash key on my UK keyboard?
    Everblue
    Posts: 168 from 2004/1/6
    I have a British Kensington keyboard. The hash key is right to the right shift, but when I press it I get a vertical line instead :(
    Any idea where did the hash key go?
    Thanks! :)
  • »15.10.10 - 14:25
    stephen_robinson
    Posts: 746 from 2007/4/22
    Have you got the correct keymap set? What happens when you press shift and 3? ? ? (which should be the UKP symbol)
    [ Edited by stephen_robinson on 2010/10/16 9:36 ]
  • »15.10.10 - 15:19
    Everblue
    Yes I selected UK keyboard over course.
    Shift + 3 = ?
  • »16.10.10 - 04:37
