Posts: 1193 from 2003/2/24
Why does it plug to a motherboard slot? I understand it would get power and data through its ATA connector.
Even when the power is off? Would be rather useless HD replacement if you automatically lost everything each time you shut down
From the page:
Fortunately, the card can draw enough juice from a motherboard's PCI slot to keep its four DIMM slots powered, even when the system is turned off. The system does have to be plugged in and its power supply turned on, though.
