Posts: 680 from 2009/10/20
USB message log Error massstorage.class Command block failed: nak timeout(10)
Device DataTraveler 2.0 High Running
Shows the device in Poseidon but not on desktop?
How do you make a mountlist?
Kingston Usbscsi0
Found Kingston Icon on MyMORPOS? Why there?
Selected all files in a work: drawer and copied then pasted in KIngstonIt hung after 20 or so files asking to skip file after file? new stick...defective?
Is the copy and paste same as a DOS command in shell?
[ Edited by osco on 2010/4/4 21:57 ]
[ Edited by osco on 2010/4/4 22:10 ]
[ Edited by osco on 2010/4/4 22:12 ]
[ Edited by osco on 2010/4/4 22:29 ]
[ Edited by osco on 2010/4/4 22:31 ]
