Moderator
Posts: 766 from 2003/2/28
dIGIMAN wrote:
I am using a SATA/PATA Adapter already with a 1 TB SATA drive in my pegasos and planing to use this in the mac mini.
Just be aware that it obviously wont fit inside the mini, space is rather constrained, but perhaps USB is good enough for your usage. Hmm.. wondering if some internal PATA/SATA adaptor could be routed to an eSATA port.. :)
I just dont wont to run into some hardware limitations of the mac mini which i dont know, stuck to a 500gb PATA drive or something.
320GB is the largest drive you can fit internally.
