Print of ATX back plate for Pegasos 1?
    kolla
    Posts: 106 from 2003/4/22
    Anyone got a postscript or PDF or whatever of the ATX back plate for Pegasos 1?
    [ Edited by kolla on 2010/1/15 6:07 ]
    -- kolla
  • »15.01.10 - 03:02
    Lizard
    Posts: 34 from 2004/4/27
    Here is a review of a mATX case for the pegasos:
    And there is also a picture of the back.
    Hope it helps a bit.
  • »15.01.10 - 08:49
    kolla
    Not much, but I think I can manage by takinga photo of my peg and draw a back plate myself. Naturally I'll post it here when I've done it. Thanks anyways :)
    -- kolla
  • »15.01.10 - 13:13
    Lizard
    On an old Morphos 1.3 CD which I got with my Peg 1, I also found a Pegasos.pdf.
    It does contain a schematic of the back plate, but I doubt the size is correct.
  • »15.01.10 - 18:04
    kolla
    Still, sounds interesting, if size is wrong it can be scaled.
    I made a rough mockup earlier today, and it too was wrong size when I printed it out :-)
    [ Edited by kolla on 2010/1/16 1:32 ]
    -- kolla
  • »15.01.10 - 22:31
    kolla
    The PDF helped alot, I now have a mockup in paper that fits :-)
    Next is to print it out on a more solid cardboard which I think I will laminate. Later on I can use a friend of mine who has a knife plotter to make something that is slightly more professional :-D
    -- kolla
  • »16.01.10 - 04:19
