Harddrive connected without power
    dake
    Posts: 204 from 2007/9/14
    Is there any risk of loss of data, if i have my backup harddrive ide cable connected and the +5 +12v disconnected?
    I want it this way so i can use an external switch for power on the drive when i need it.
    My Pegasos will ofcourse be powered off when i change the switch.
    The reason is that im not using the backup harddrive often, and its noisy and i dont want to open the case to enable disable the drive.
  • »20.09.08 - 06:08
    dake
    To be a little bit more clear:)
    Is there any chance that my other harddrive get collisions if i do this.
  • »20.09.08 - 17:18
    Korni
    Posts: 472 from 2006/2/23
    There is an IDEStanby command included in MorphOS. No need to manual turnoff. Oh, well, there shouldn't be any problem but is that hard to disconnect an ide cable anyway? :P.
    [ Edited by Korni on 2008/9/20 21:41 ]
  • »20.09.08 - 17:59
    dake
    @Korni
    Its not hard to disconnect the ide cable, but i dont want to open the case everytime:(
    I used IDEStanby earlier, but you know i do alot of crazy stuffs on my Peg, programming and trasching memory, i stress her alot:) so sometimes i reboot her often, and every boot the noisy harddrive is spinning up again.
    I want to be kind to my harddrive not letting it spin up and down alot.
    And i dont want to wake my girlfriend everytime i reboot the computer:)
    [ Edited by dake on 2008/9/20 22:05 ]
  • »20.09.08 - 18:59
    Get27
    Posts: 90 from 2004/8/23
    Hello,
    If you disconnect power, HD's components will receive data (0/5V) without be powered, it's not safe.
    why dont you use a rack ?
    It's the better solution IMHO.
    PowerMac 3.5, G4 1.0GHz DP, 1GB ram, 80GB HD + NAS, Radeon 9600 128MB Mac, 1680x1050
    PowerMac 7.3, G5 2.3GHz DP, 4GB ram, 160GB HD + NAS, Radeon 9800 128MB PC, 1680x1050
    Amiga 500+, Vampire 500v2+, HxC Floppy
  • »20.09.08 - 22:11
    dake
    @Get27
    thanx, i forgot the logic 5V in the cable, you are total right, it cant be safe.
    I will retire this drive and get a new silent one instead.
  • »21.09.08 - 06:31
