Help! Can't boot MorphOS 1.4.5 on PUP
    Hexagon
    Posts: 2 from 2007/8/15
    When I read about Efika, and the new great MorphOS 2.0 + sputnik I remembered the good old days of a great operationg system, and blew the dust of my old AmigaPPC hoping to get the current MorphOS up and running.
    I've tried for some days now, with only a black screen after the first reboot. I have read that alot of people have the same problem, but for them "nokickstart" and using the idehack module did the trick, except for other errors in the s-s file.
    I've tried all of the above, and can't get it to boot. I've also tried to copy the "Boot" directory from an older release, without any success.
    I have an Amiga1200T with BlizzardPPC+ with 603p/240MHz and MC68060RC60. BlizzardVision GFX card and 2 x 64MB of EDO ram. When testing I had only one drive connected to the blizzard scsi chain, and none on the stock scsi.device
    If anyone have any suggestions to try out I would appreciate it :-)
  • »16.08.07 - 08:51
    Hexagon
    Thanks Skolman for your reply. I have the same file sizes as you have.
    However, I'm typing directly from Sputnik now  :-)
    I managed to get it working. I reformated the partition, and selected
    "international" which was not chosen. Then recopied the CD. It
    worked. GREAT ;-)
    Anyway, I downloaded MorphOS 1.4.5 with Ambient 1.41SE as far as I
    have read. When I select "about" in the menu I get MorphOS 1.4 and
    Ambient 1.41. Is this correct, or does it excist another newer version??
  • »17.08.07 - 17:44
