Enforcer under MOS
    amigafil
    Posts: 23 from 2003/9/6
    Hello every body !
    Is there something like Enforcer under MOS ?
    Thank's
    Powerbook and Pegasos II G4 MOS 3.7  :-)
  • »27.02.04 - 19:43
    marcik
    Posts: 268 from 2003/4/12
    It's inside MorphOS - connect terminal to yours Pegasos serial port and you will see enforcer-like debug output, or use ramdebug to get those hits without other computer.
  • »27.02.04 - 19:58
    Gelb
    Posts: 148 from 2003/3/4
    .. or logserver
  • »27.02.04 - 20:38
    MarK
    Posts: 641 from 2004/1/25
    hello ppl,
    didn't anything change about this? i'm working on my large project, but it from time to time dies... probably because of some illegal hits. any way to catch them and display them simplier than by ramdebug? i have also the ramdebuglog viewer, but it can't compare with enforcer. it is even possible to implement it with morphos?
    is there a way to catch ramdebug log completely? and to filter it, to not to display those non important information? here it's limited to (afaik) 256 kb, and it's not enough... when one hit happens, than it's covered by millions of other hits... which removes those first (important) hits...
    any help?
    thanks in advance!
    bye, MarK.
  • »26.01.07 - 10:30
    Henes
    Posts: 507 from 2003/6/14
    http://www.biclodon.com/documentation/morphosdebug/
    Read the chapter 1 part 3.
    Also see the FAQ for the maxhits option.
    [ Edited by Henes on 2007/1/26 13:39 ]
  • »26.01.07 - 10:38
    Wishmaster
    Posts: 342 from 2003/6/29
    RTFM :-)
    Pegasos PPC
  • »26.01.07 - 11:21
    MarK
    @Henes: thanks! but this doesn't solve my problem with ramdebug overload. is there a way to expand the ramdebug log size limitation? or to limit the amount of the debugging data?
    thanks in advance!
    bye, MarK.
  • »26.01.07 - 11:56
    merko
    Posts: 328 from 2003/5/19
    Yes, the maxhits option.
  • »26.01.07 - 16:28
