No Booting without keyboard on PEG 2 ?
    judas
    Posts: 175 from 2005/1/14
    I tried to usemy PEG2 with an USB keyboard or even without a keyboard. But all I see is the Bplan-Logo, than it locks completely.
    Is this really true that you cannot run it without keyboard ?
    bye
  • »05.08.06 - 05:40
    GK_LKA
    Posts: 481 from 2004/3/28
    My Peg boots without keyboard, you only have to wait a while when the bPlan logo appears.
    There is also a newer OFW, which supports USB keyboards (partially), try that.
    [ GK / LKA Team ]
  • »05.08.06 - 05:44
    judas
    I use a version called V 1.2 ...which shoudl be the latest ...
  • »05.08.06 - 05:45
    Posts: 154 from 2003/4/22
    If for any reason, the OFW can not find a compatible keyboard, the full console (output and input) should fallback to "/failsafe". In this case, it is the serial port.
    The computer probably boots fine but you just do not see the prompt because it's on the serial port.
    Your sincerly
    MorphOS Rulez !
  • »05.08.06 - 09:59
