Initializing USB2.0 card problems
    GK_LKA
    Posts: 481 from 2004/3/28
    I have a VIA EHCI (USB2.0) PCI card, and have the same problem as had with the VIA network card: If I boot linux (latest kernel), and then try to use the card in MorphOS, it doesn't work, I think linux initializes it somehow, and then MOS can't use it this way. The only solution is the well-known plug-off-the-power-cable-from-your-computer magic technic :(. Is is there a fix for that? Or can anybody write a patch like the viarhine-wakeup?
    [ GK / LKA Team ]
  • »08.06.06 - 08:16
    CISC
    Posts: 619 from 2005/8/27
    You fail to mention if it's UHCI that dies, or EHCI (what driver are you using in that case?), or both...
    If UHCI dies, one could only wonder why Linux doesn't give the same treatment to the onboard one? If it's EHCI, you need to talk to the author of the driver.
    - CISC
  • »08.06.06 - 14:26
    GK_LKA
    On MOS I use the card only in USB1.1 mode (I think this is UHCI.) because there is no other solution yet...
    [ Edited by GK_LKA on 2006/6/8 18:52 ]
    [ GK / LKA Team ]
  • »08.06.06 - 15:49
    beanbandit
    Posts: 50 from 2006/4/19
    arakattack supports EHCI 2.0, and works under MOS (not native but...)
    it also has some issues with the 'built-in' UHCI driver,
    to make it work better you must 'patch' the openUSB.device.
    it isn't perfect... but it works, and is free.
    both OHCI and UHCI is USB 1.1 UHCI is the slower of the two
    (requires more CPU power for the same speed)
  • »08.06.06 - 17:56
    Schlonz
    Posts: 131 from 2004/4/16
    I dont know how you get ArakAttack working with MOS... I tried *everything* I could imagine but it did not work for me.
    I tried three different USB 2.0 cards with three different chipsets, I tried Poseidon V2.2 and V3.2, I tried the old shareware ArakAttack version (both registered version and demo version), and I tried the new "free" version of it, and everything in every combination... nothing helped, the whole system freezed after a couple of seconds using my USB 2.0 stick. I even discussed that with the author of ArakAttack, and he said that the whole OpenPCI stuff is very fragile / buggy.
  • »08.06.06 - 20:03
    gunne
    Posts: 441 from 2003/2/25
    Schlonz,
    Which model Pegasos do You have ?
    I wrote a short guide at Pegasos.org here: Pegasos.org - Wiki
    It worked when I tested it on Pegasos II.
    Best wishes, Gunne
  • »08.06.06 - 20:32
    GK_LKA
    Downloaded, installed, and it works. Tells me that it is USB2.0 but it is still running with 1.1 speed. (Tryed with my new pendrive - pc reads from it @ 12MB/s, MOS does the same with 7-800kB/s (don't know exactly, but it was very-very-very slow).
    So, to be ontopic - is init the job of poseidon?
    [ GK / LKA Team ]
  • »09.06.06 - 06:51
    CISC
    Hopefully platon42 will release an update soon, containing the new uhciusb.device, which should give full 1.1 speed too...
    No, the drivers are responsible for initing the hw, however I don't see why Linux would do anything different to the onboard VIA vs your PCI VIA?
    - CISC
  • »09.06.06 - 12:06
    GK_LKA
    Don't know either, but believe me, it does :D (molk kernel does the same).
    Do you have any idea to test it to clarify exactly what is the problem?
    [ GK / LKA Team ]
  • »10.06.06 - 09:14
    Schlonz
    Hi Gunne,
    I have a Pegasos 2.
    Thanks for your hint with the short guide, but it simply says "install ArakAttack and use it". But, this does not work for me here, I just tried it again. I simply get system freezes, and sometimes, if I am lucky, it works for a few seconds and Poseidon gives _a lot_ error messages sayin "Houston, we have a problem! P2V undetected!". But I never get USB2 speed.
  • »10.06.06 - 20:44
    CISC
    No, sorry, I don't (short of dumping all the regs and comparing working vs non-working). :P
    - CISC
  • »10.06.06 - 21:04
    Posts: 154 from 2003/4/22
    the Linux EHCI driver sat up some register and 'owns' each high speed/USB 2.0 port. On a device connection, this driver is responsible to probe the speed. If it's a low/full speed device then the port ownership is relead and the conpagnon chip (UHCI or OHCI) see a device connect event. If it's an high speed device then the driver continue the init/connect process.
    However, on reset the EHCI chipset should NOT own the card (this should be only set by the driver). But, some cards/chipset doesn't reset the appropriate bit and the port ownship is stuck to the EHCI even after a reset.
    In your case, I guess the Linux EHCI driver is loaded, own the port and on reset the 'ownship' bit isn't reset then the EHCI chip still on the part but there are no driver on MorphOS to either use the device as an high speed device or to release the port to the conpagnon.
    I hope I've been clear ;-)
    Regards.
    MorphOS Rulez !
  • »11.06.06 - 06:38
    GK_LKA
    @ NicoPPC:
    It's clear, thanks :). Now I have only one question: where is MOS1.5 with the USB2.0 drivers?? :D
    [ GK / LKA Team ]
  • »11.06.06 - 10:27
    Posts: 140 from 2003/9/16
    Im up to donate whatever USB 2.0 PCI card that any developer wants in order to give us a working full speed 2.0 driver for MOS.
  • »12.06.06 - 07:07
    Schlonz
    Currently there is a discussion about USB2 on the MorphOS Mailing List.
    There I found a hint how to get my USB2 card (NEC chipset and ArakAttack 1.19) working: by setting the usb-enable env to "false" in the Open Firmware.
    Now I at least get the USB2 card working without crashing within seconds, but still I get no USB2 speed. My massstorage devices are only recognized as "Fullspeed" devices, but as they are USB2.0 compliant devices they should be recognized as "Highspeed", just as the EHCI hub which is built-in in my USB2 card.
    Does anyone know how I get Poseidon (or ArakAttack) to recognize these USB2.0-devices as Highspeed-devices?
  • »02.07.06 - 23:10
    CISC
    That was indeed a good tip (which I wasn't aware that you could do until now), which should save a few people from OFW 1.2 caused problems...
    The best thing would perhaps be to ask the ArakAttack author? If you have latest Poseidon a High-Speed capable driver should work (provided the device you are connecting actually is High-Speed (it doesn't have to be just because it's marked as USB 2.0 compatible)).
    - CISC
  • »03.07.06 - 00:14
    Any USB 2.0/UHCI card should already be running in full-speed.
    I do not think it's worth to send a USB 2.0 card to a motiaveted developper/ The "packaging and posting" cost is highr than the card itself ;-)
    Bye
    Nico
    MorphOS Rulez !
  • »03.07.06 - 19:52
    FLComputer
    Posts: 22 from 2005/9/26
    @NicoPPC:
    If someone wants to do that, why not ?
    I agree that a real USB2 highspeed solution which would work with Nec USB2 cards as well as with VIA USB2 cards would satisfy many people.
    Transferring 4GB for a backup for example is very very very slow on external harddrives !
    Faranheit
    I.M.M. Informatique : YOUR Efika Reseller for France, Luxembourg and Belgium !
    Mail : laurentz@informatique-imm.lu
    Site : http://www.informatique-imm.lu
    ICQ : 81617715
    Skype : faranheit57
  • »05.07.06 - 06:32
    SoundSquare
    Posts: 1214 from 2004/12/1
    how ?
    what about the usb2 driver that was demonstrated a long time ago ?
    will it be released one day ?
  • »05.07.06 - 08:42
    Schlonz
    "full-speed" = maximum speed of USB 1.1, i.e. up to 12 Mbit
    "high-speed" = max speed of USB 2.0, i.e up to 480 Mbit
    So, its right that USB2 cards are already running at full-speed (well, kind of; they are not as fast as the onboard USB1.1 controller) but we all want them to run in high-speed mode.
  • »05.07.06 - 10:12
    SoundSquare
    @Schlonz
    alright thanks for the explanation.
    This "full-speed" stuff is tricky.
  • »05.07.06 - 13:23
    Henes
    Posts: 507 from 2003/6/14
    You should better ask him if it will be finished one day and/or if the stuff it is built upon will be finished one day.
    If it does not happen it makes no sense to discuss about a release.
  • »05.07.06 - 17:53
    magnetic
    Posts: 2129 from 2003/3/1
    henes
    interesting, what was it "built on"
    magnetic
  • »06.07.06 - 03:29
    beanbandit
    OF 1.3!?
  • »07.07.06 - 23:58
