Posts: 220 from 2003/11/14
Adapters from ACS Control work fine with Pegasos I and Pegasos II.
They don't have a distributor in Europe, do they ?
(I once contacted mach5products, the company producing the mounting plates for ACS' adapters, they didn't).
There is another company (German) which makes another set of boards which are much the same.
Can you remember the name, please ?
My experience with CF->IDE-adapters with my Peg is:
When I bought my Peg II 20 months ago, I also ordered a CD->IDE-adapter from
http://stores.ebay.de/NRG-Systems-GmbH.
As it doesn't support cable select, I configured it as master (my changeable hard drive as slave).
I took an uptodate 256 MB CF-Card from SanDisk, formatted it in my Psion mxPro and copied some files to it. Then I connected it to the adapter.
The OF recognized the "IDE" drive. I could also list the files on the card.
Linux recognized that there is a drive, but couldn't access it (dma timeout). Starting the Linux Kernel with nodma option "solved" this problem. I could access the drive, create partitions, ext2 format it, copy files to it...
MorphOS however - the OS I bought the card for - did not even recognize that there is something connected to the ide bus (had a look at serial output of the kernel when booting)
So the adapter works, the card works, MOS doesn't.
(similar problems with DVD-RAMs, but that's another topic...).
