HD Trouble
    artickfox
    Posts: 101 from 2004/4/17
    I have buy an extra Hard Disk for ma Pegasos, but I have a problem...
    At first boot, OF "see" this HD normally, but if I reset and reboot again, OF don't recognize it anymore and not see it!  :-?
    Also: if i start MOS, the HD seem disappearing from hardware list, no matter if first it was recognized by OF. Also seem it make trouble to boot Linux during hardware detection.
    Hard Disk model is a Samsumg, 80 Gb, ATA.
    Maybe is a problem of incompatible hardware?
    Maybe there are some model of new Hard Disk not compatible with Pegasos Board?
    Virtual Paws:
    http://www.furryitalia.net/virtualpaws/index.htm
    Italian furry videogame site
    Furry Italia
    Italian Furry Comunity
    - Owner of a Pegasos 2/G3 -
  • »03.10.05 - 13:42
  • Visitor
  • Try using the drive on its own cable
    or check the cables compatable or the master/slave/cable select settings are correct
    Chech to see if they are the same modes like ATA100 and not different ones this can cause problems too.
    Cheers
    Robert.
    www.amber-inc.com
  • »03.10.05 - 21:07
  • TCD
    Posts: 5 from 2005/9/4
    I've got the same problem from time to time. What I did: I just unplugged power molex from my dvd drive and system boot without any problems, after that I switch peg2 off and I put molex back to the DVD drive and system boot fine. Anyway it's very strange :-)
    Actual Machine: Pegasos2, G4 1Ghz, 512 Mb Ram, Radeon 9250 128 Mb, Soudblaster Live 5.1, Samsung 160 Gb, BTC DVD-RW 8x drive, All together in lovely Antec Aria case.
    Operating Systems: MorphOS 1.4.5, Ubuntu Breezy Linux, MacOSX 10.3.9 (Linux emulation)
  • »04.10.05 - 03:33
