would this case work
    poundsmack
    Posts: 1346 from 2003/6/7
    would this work as a PEG case?
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »03.08.04 - 06:39
    warface
    Posts: 653 from 2003/2/24
    Most probably.
  • »03.08.04 - 06:46
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 01.09.2011 - 16:58 ]
    Pegasos2 G3, 512 megs RAM
  • »03.08.04 - 07:28
    Golem
    Posts: 766 from 2003/2/28
    @poundsmack
    MorphZone has a search function, use it.
    (yes, the case will work)
  • »03.08.04 - 10:02
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    @poundsmack
    I was hoping you would ask the question for me "Do Pegasos1 G3 CPU cards work in the Pegasos2?"
    :-D
    Answer: apparently peg1 G3 cpu cards do not work in peg2. This is a shame, as these CPU cards could have been re-used, generating lower cost Pegasos2 based systems.
    As for peg2 cases...
    I like this case! (click here)
    [ Edited by Darth_X on 2004/8/3 17:56 ]
  • »03.08.04 - 12:57
