Pegasos II Digital Out?
    MaSC
    Posts: 63 from 2003/12/1
    Is the Digital Output on the pegasos II usable or is there any planned support in the future?
  • »11.01.04 - 13:40
    magnetic
    Posts: 2129 from 2003/3/1
    Hello
    If you are referring to the SPDIF Digital Audio out it does work. I'm not sure if there is a seperate driver (in beta probably) or if it works as is. One way to find out is to try it! :-D I do know ppl have had it working great.
    magnetic
  • »11.01.04 - 14:39
    MaSC
    I am and I have, (smart ass :-D  ;-) ) I am just trying to figure out how to get it to turn on.
  • »12.01.04 - 11:38
    magnetic
    Are you on the beta2 mailing list? If so you should ask this question there and you will be helped. If not, then you need to join ask your dealer or email genesi.
    magnetic
  • »12.01.04 - 19:05
    hiTCH-HiKER
    Posts: 169 from 2003/12/31
    Does the SPDIF digital out work now? Anyone using it?
  • »15.05.04 - 12:04
    MaSC
    No, not yet. Maybe in 1.5 eh? ;) ;) :)
  • »15.05.04 - 14:49
    magnetic
    AFAIK
    There is a beta internal driver for it. nothing public as of yet.
    Thomas
  • »15.05.04 - 15:36
    Jupp3
    Posts: 1193 from 2003/2/24
    I think it already works on Linux, not sure about that though...
  • »15.05.04 - 19:11
