*Working SCSI Cards with Pegasos*
    magnetic
    Posts: 2129 from 2003/3/1
    Hello Morphers..
    Here is info I got through experience. Other users should please add their input.
    Working PCI SCSI Cards for Pegasos
    Symbios 810 chip
    Symbios 825 chip (UWSCSI)
    NOT WORKING
    ALL Symbios 875 Controllers do not work with this OF version.
    Heard Working:
    SYmbios 895
  • »13.05.03 - 02:20
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    Hi magnetic,
    Thanks for your research work on SCSI cards. I know, when I get my pegasos assembled I will be looking for a SCSI controller card, I have a SCSI JAZ drive 1GB cart drive with a lot of amiga stuff on it (500MB of OctaMED music and samples alone!).
    For the Pegasos resellers, please consider trying to acquire some of these working cards to sell. :-D
  • »13.05.03 - 02:40
    Posts: 126 from 2003/2/17
    That's not a general case...
    Problems encountered to get decent SCSI support are not linked to the chip but to different card design... so every card tested works with MOS without pb, exept 895 where there is a small problem to fix.. Concerning the firmware path, My 810 and one model of 875 is working correctly... So the fect you buy a 810 doesn't give you any guarantee of good functionning NOW.
    Hope this is clear.
    I already tested a non working 810 card for info
  • »13.05.03 - 03:18
    magnetic
    Ok Falcon
    Thanks for clearing this up. I heard all 810 cards worked... My card is a Symbios Logic brand PCI card and it works great so far. 825b chip
  • »13.05.03 - 04:33
    Posts: 52 from 2003/4/9
    The LSI8750SP which is Symbios 875 does not, even though the HCL states it is. :-(
    In fact the mobo will not even boot up with it in any of the PCI slots.
    Rob
  • »13.05.03 - 11:57
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    OK. SO I finally got my 825 based card in the mail. It has no 'BIOS' screen more typical of an adaptec card
    1. Is there usually any way to setup e.g. auto termination?
    2. It has an internal 68pin UW and external, is this a single 'through' bus?
    3. It also has a 50pin connector..is this likely on the same bus as the 68, or it's own channel?
    4. In MorphOS, should there be a device entry e.g. ncrscsi.device or somesuch?
    5. I ran PCIscan and it says detected parity error...no idea if this is good or bad to be honest.
    I will try to hook up a scsi drive and some terminators this evening so I may have more news then but if anyone can give a few clues to the above...that'd be great
    Steve  ;-)
  • »15.05.03 - 16:48
    magnetic
    I will answer as best I can but I dont know much about the card either... no docs and no time :p
    1. I think auto termination is enabled automatically
    2. I think the ext is terminated unless you plugh something in..
    3. I THINK its dual channel, not sure
    4. The device is symbios.device
    5. ???
    When you hook up a device to the card the Scsi Config tool should recognize it and show the device (symbios.device)
    Good luck. If you find out info.. post it up
    magnetic
  • »16.05.03 - 00:15
    magnetic
    THe Current PEG OPen Firmware has trouble with 875 chip - I had same problem... system is dead with it... Get an 810 or 825 they work for sure - I heard 895 might work too...
    magnetic
  • »16.05.03 - 00:17
  • News Moderator
    News Moderator
    Darth_X
    symbios 815 NOT working here!
  • »11.03.04 - 15:41
    magnetic
    LSI Logic Symbios 8951u working here on Peg2 very reliably! 80mb/s transfer :D
    I'm also selling them Brand New for $39.95!!!
    $10 shipping INTL
    magnetic
  • »11.03.04 - 16:47
    zeXar
    Posts: 30 from 2003/7/22
    SYM8750SP with SYMBIOS LOGIC 53C875J chip does not work. :-?
    Pegasos II G3/600MHz
    AMIGA 4000 060/50Mhz 604e/233MHz
  • »12.03.04 - 00:00
    FYI information, every information given here is without any value, if the firmware version is not given... lots of SCSI problems were fixed in firmware embedded with pegasos2... si give more informations :)
  • »12.03.04 - 08:59
    Posts: 8 from 2004/2/27
    Symbios 895 chip (U2WSCSI3) is working fine, too.
    byby
    KIKI
  • »13.03.04 - 19:36
