Any experince with USB floppy drives on PegII?
  • EWS
    Posts: 6 from 2004/2/21
    Is there any trick to it?
    Listing of drives that do or don't work?
    Things to do? to avoid?
  • »25.02.04 - 05:31
  • -D-
    -D-
    Posts: 118 from 2003/5/1
    I attempted a cheap TDK USB drive...and couldn't get it to work.
    I tried adjusting some of the USB parameters, but must confess I
    had no idea what the hell I was doing. :D
  • »25.02.04 - 05:55
  • Targhan
    Posts: 2833 from 2003/2/7
    I would think you would need L:fat95 for reading PC formatted floppies, but that's just a guess.
    :idea:Targhan
  • »25.02.04 - 06:20
    Leon
    Posts: 93 from 2003/11/28
    I use a MITSUMI USB Floppy drive with the Peg2. It works fine till yet. I have fat95 installed. When u have problems with USB drives, play around with the device settings (which is massstorage.device, like increasing the buffer size) in PosedionUSB Prefs. I had my 1024MB FlashDisk working like this.
    Proud owner of:
    Efika
    ABIT ATI 9200SE AGP 128MB
    40GB Samsung Hard Drive 5400rpm
    PowerMac 3.1 G4 350Mhz "Sawtooth" AGP
  • »25.02.04 - 17:32
    Posts: 126 from 2003/2/17
    I tested a TEAC floppy drive on peg1 worked without problem to read PC
    floppies...
    shouldn't be different on pegII.
  • »25.02.04 - 18:22
  • -D-
    -D-
    Whoa, mine's working fine now also...maybe I didn't have
    fat95 installed when I first tried it (although I thought I did).
    After buying this drive for my Mac, I thought USB floppy drives
    where hideously slow and terrible...but it actually works "reasonably"
    well on the Pegasos. Cool! :)
  • »26.02.04 - 03:52
    Leon
    I don't think there is a reason why USB floppy drives should be slower than normal floppy drives, considering the transfer rate of a floppy drive is much much lower than the USB bus can afford.
    Proud owner of:
    Efika
  • »26.02.04 - 12:01
  • -D-
    -D-
    I agree...to rephrase, USB floppy drives work horrible
    under OSX. The transfer rates are fine, it's the
    time from when the drive is plugged in/disk inserted,
    to when the volume is finally mounted and useable. Probably
    a shortcomming or bug in my version of OSX, as it works
    well enough on the Pegasos/MOS (haven't tried it on my Windows
    machine yet).
  • »27.02.04 - 06:56
