Powermac G4 MDD audio problems
    CountRaven
    Posts: 566 from 2007/12/10
    Hello to the forum.
    I have built yet another MDD Powermac G4, it is dual 866 cpu with original Radeon Mac edition card and a usb 2.0 card. All great but when I plug a Soundblaster live card and choose to boot on MorphOS the computer turns off!!! Perhaps not enough power for so many cards? If I boot on MacOSX, no problem....
    Plus
    Is there a hope for the original audio driver to work correctly on MDD? Very low volume or no sound at all so far, on both my MDDs, Why?
    [ Edited by CountRaven 04.10.2013 - 13:43 ]
  • »04.10.13 - 10:42
    redrumloa
    Posts: 1424 from 2003/4/13
    I don't know about shutting off with SB Live, sounds like the card may be bad. AFAIK OSX doesn't have drivers for the SB Live, so maybe it isn't initializing it?
    The MDD in my experience has audio but low. IIRC you should maximize the audio slider in OSX and reboot into MorphOS to get improvement.
  • »04.10.13 - 12:33
