ScummVM 0.13.0 broken?
    dIGIMAN
    Posts: 273 from 2005/11/7
    Hi guys,
    someone using ScummVM regulary?
    After switching to Fab's port of ScummVM 0.13.0, i cant save the gamestate anymore.
    I get this the log below.
    After switching to 0.12.0, everything works again.
    Am i the only one?
    6 [10] Work:Games/ScummVM/scummvm *Lock DH3:Games/ScummVM/.scummvm/ Read OK
    7 [10] Work:Games/ScummVM/scummvm #LOC_OBJECT 0000083C, 0000B606, 00000C43 DH3 OK C175B78
    8 [10] Work:Games/ScummVM/scummvm #EXAM_OBJECT 00000C17, 00005B78 DH3 OK FFFFFFFF
    9 [10] Work:Games/ScummVM/scummvm #COPY_DIR 00000C17 DH3 OK C175B8E
    10 [10] Work:Games/ScummVM/scummvm #FREE_LOCK 00000C17 DH3 OK FFFFFFFF
    11 [10] Work:Games/ScummVM/scummvm *Lock DH3:Games/ScummVM/.scummvm/ Read OK
    12 [10] Work:Games/ScummVM/scummvm #LOC_OBJECT 0000083C, 0000B606, 00000C43 DH3 OK A921E8C
    13 [10] Work:Games/ScummVM/scummvm #EXAM_OBJECT 00000A92, 00001E8C DH3 OK FFFFFFFF
    14 [10] Work:Games/ScummVM/scummvm #FREE_LOCK 00000A92 DH3 OK FFFFFFFF
    15 [10] Work:Games/ScummVM/scummvm *Lock DH3:Games/ScummVM/.scummvm/maniac.s02 Read Fail
    16 [10] Work:Games/ScummVM/scummvm #LOC_OBJECT 0000083C, 0000B606, 00000C43 DH3 Fail CD
    17 [10] Work:Games/ScummVM/scummvm Lock Games:ScummVM/.scummvm/maniac.s02 Read Fail
    18 [10] Work:Games/ScummVM/scummvm #FREE_LOCK 00000C17 DH3 OK FFFFFFFF
  • »19.04.09 - 22:50
    Jambalah
    Posts: 820 from 2008/3/30
    Playing this very moment The Secret of Monkey Island 2 with vers 0.13.0
    I made two save-game and all went ok.
    Just to verify all was ok I exited from the game and run it again. Then I tried to load the saved game and even this operation went good.
    Could it be an overwrited file to cause the problem?!?
    Try to check "scummvm.ini". There's a voice that configure the place where the savestates are stored: savepath=Games:Scumm/ (or whatelse) and so on. Maybe is pointing to another place and it generate a "fail".
    Sorry but I can help much more....
    [ Edited by Jambalah on 2009/4/20 15:15 ]
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »20.04.09 - 11:02
    dIGIMAN
    Atleast u tried :)
    Well i know now that it works for you.
    Strange is, when i switch to 0.12.0, savegames work again with the same ini.
    The path is there and i also tried to use a new one, still no success.
    Strange.
  • »20.04.09 - 11:27
    pecanK
    Posts: 70 from 2004/11/5
    I haven't tested 0.13.0 yet but I remember I had some problems with older Scumms due to sdl.library.So compare what versions of the lib you are using.And generally some progs behave differently under MOS 1.x and 2.x...
    pecaN of the Czech PowerPC User Group
  • »20.04.09 - 14:26
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    @dIGIMAN
    I can't see such issue here, it loads from the configured save path directory.
    Not sure what happens for you, but you could easily trick it by putting saves in that .scummvm/ dir anyway.
    But, just in case, redownload the archive. I remember i had replaced the archive a very short time after "official release on irc" (which is why i didn't bother bumping it). But i really can't remember what this hotfix was about, so maybe that was your very issue. :)
  • »20.04.09 - 15:47
    dIGIMAN
    Fab wrote:
    @dIGIMAN
    Thats were i had the savegames in the beginnging but the hint to redownload the archive did it.
    Strange, guess there really was a problem with my version. Now also 0.13.0 does saving for me,
  • »20.04.09 - 17:08
