Feeble Files not running?
    Posts: 56 from 2003/3/16
    Someone please give me the answer!.
    I installed feeble files, try to run both 68k an ppc, select screenmode 8 bit voodoo3, then a black screen then back to the desktop. any ideas??
    thanks
    david
  • »26.09.03 - 16:59
    Spidey
    Posts: 568 from 2003/2/24
    Hello djbmister,
    Perhaps something to do with your Voodoo3?
    I just installed the whole game on my harddrive and I've got a Radeon9000.
    Everything just works normally.
    Another option: the game is in 640x480 screen size or so. Can your gfx handle that in Ambient?
    Spidey
  • »26.09.03 - 17:22
    hi spidey,
    I figured it out, feeble files needs to be installed in a directory, i was installing it on the root of the drive. strange?
    thanks for your help
    david
  • »27.09.03 - 06:22
