Myst for Amiga on MorphOS (SOLVED)
    pan1k
    Posts: 147 from 2009/1/20
    Trying to get Myst for Amiga to run on Morphos. I tried the Myst.CGFX and I get the MYST.CGFX.exe is not executable error. Has anyone tried running this? I'm pretty sure the AGA version won't run.
    Update: Problem is resolved. I downloaded the 1.1 update and for some reason it didn't fix it. I ran the executable from the Ram Disk, that worked, copied it to the game directory and it works now.. weird.
    [ Edited by hooligan 26.04.2014 - 19:53 ]
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »26.04.14 - 13:53
