RTCW Installer
    amiga-dave
    Posts: 8 from 2014/3/8
    I have downloaded RTCW and when i double click the installer a pop up box says " the disk you are running the installer fromdoes not have enough free space to complete the installation. You need at least 808MB free disk space to complete the installation "
    I have more than enough space.
    My machine a mac mini g4 1.5 Ghz 64MB VRAM running latest stable release morphos 3.5.
    Any help would be appreciated.
    Dave
    [ Edited by amiga-dave 21.04.2014 - 15:24 ]
  • »21.04.14 - 12:23
    XzIt
    Posts: 250 from 2005/1/19
    "Unpack morphosrtcw.lha to your hard disk and doubleclick the 'Installer' icon.
    The installation will begin automatically."
    So are you trying to run the installer from your hdd or ram? ;P
    seem to recall you have to put the installer where you want it installed, can be mistaken..
    could be that simple problem if *not* use snoopdos ;P
    X
    [ Edited by XzIt 21.04.2014 - 16:44 ]
  • »21.04.14 - 12:42
    amiga-dave
    thanks for trying to help but still says the same thing
  • »21.04.14 - 12:54
    amiga-dave
    anyone else experience this problem?
  • »21.04.14 - 14:05
    amiga-dave
    got it sorted, all is good
  • »22.04.14 - 12:34
