VICE 2.2 sound "choppy"
    TheMagicM
    Posts: 1220 from 2003/6/17
    When I run VICE 2.2 on my G5, gfx are smooth, some sounds are smooth, but in general, the sound is choppy. Anyone experience this ?
  • »10.06.13 - 23:29
    Doffo
    Posts: 508 from 2010/10/14
    Yea. I also have the same experience, but even in my Mac Mini or MDD.
    YUUUP!
  • »11.06.13 - 00:29
    TheMagicM
    Damn.  :-(
  • »11.06.13 - 00:39
    TheMagicM
    I'll try that out. Thanks!
    EDIT: that didnt fix it. Another thing is that the screen looks strange...not as sharp.
    [ Edited by TheMagicM 11.06.2013 - 06:14 ]
  • »11.06.13 - 08:41
    Jambalah
    Posts: 820 from 2008/3/30
    Hi all!
    To listen smooth sounds & music with Vice 2.2/2.4 go to Settings/Sound settings and select "Large" in Fragment size options menu.
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »11.06.13 - 15:20
    TheMagicM
    Jambalah: that worked! Thanks! How about the non sharp screen in 2.4?
    EDIT: what I mean by "blurry", it looks like double scan isnt enabled.
    [ Edited by TheMagicM 11.06.2013 - 21:18 ]
  • »11.06.13 - 23:53
    Jambalah
    Here the screen is sharp. When double scan isn't enabled you should see a display full of lines.
    You can check if double scan is enabled in Options menu. Take a look to Overlay option too: if is enabled try without because it makes display a little blurry. Another think to check is inside Settings/VIC II video settings/Render filter settings where you can activate two filters: CRT emulation (remember that nice old monitor scanline effect? A pleasure for the eyes...  :-) ) or Scale 2x (wich makes everything blurred-like). Select "None" if one of those two is activated. Inside Settings there is VIC-II settings too but non needs to modify it (unless you want to try and see how it looks like). Tips: if you try to modify something like Double Size (inside Options menu) do that without the Fullscreen options activated since program often crashes. When you go from a double size screen to a normal screen and vice versa you will notice that display won't be refreshed. So do a soft/hard reset or go fullscreen and come back.
    Pegasos II 1 ghz
  • »12.06.13 - 04:36
    TheMagicM
    @Jambalah:
    You come thru once again!! :-) That was it..setting VIC II to "none" adjusted the display. WOO HOOO!!!!!
  • »12.06.13 - 09:10
